Activity › Forums › Adobe Premiere Pro › File size reduction for photo/video
  • File size reduction for photo/video
    Posted by Cale Henderson on February 5, 2018 at 11:22 am
    I have 43 minutes of voice over on my audio track along with a little music.
    I have 3 still images spread out on my video track.
    This is basically a glorified PowerPoint presentation. I’m trying to export the video in a manageable file size, but 43 minutes is pretty enormous. I have a basic understanding of long gop and how frames can reference previous frames to help with compression. I can’t figure out how to lower the file size without crippling the bit rate.
    Cale Henderson replied 8 years, 7 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    February 5, 2018 at 11:29 am
    If there’s nothing happening you don’t need to put a lot of bit rate for the video. The encoder should use only what it needs so if you have stills it should keep the bit rate pretty low.
  • Cale Henderson
    February 5, 2018 at 11:37 am
    I dropped the bit rate to 2 mbps. That was a little too small since there is some text on the screen… but even at 2 mbps it results in a 1.6 GB file.
  • Jon Doughtie
    February 5, 2018 at 2:16 pm
    What wrapper and codec are you using for your final deliverable?
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Cale Henderson
    February 5, 2018 at 6:31 pm
    H.264 / MP4
