Activity Forums Compression Techniques File size limit in Cleaner XL?
  • File size limit in Cleaner XL?
    Posted by Jason Hunter on December 9, 2005 at 7:29 pm
    I am using Cleaner XL (ver.6.0.2.402 Service Pack 1) to compress a 19 GB QT file. The client wants a compressed file to be QT using the video codec, 320 x 240. During the lengthy compression process it built a _work.mov file that contained 700,000 KB at its peak. It took Cleaner almost 5 hours to chug through it and when it finished it left me with a QT file that contained 0 KB.
    The same horrible thing happend when I ran compressed through Sorenson Squeeze 4.0.
    Has anyone experienced this problem? Does anyone know if there is a limit as to what you can compress through Cleaner XL?
    Many thanks
    Jason H.
    Jason Hunter replied 20 years, 9 months ago 2 Members · 2 Replies
  • Ben Waggoner
    December 9, 2005 at 9:30 pm
    Well, you sure don’t want to be using the “Video” codec. It’s from 1991, and code named “Road Pizza.” It was superseded by Cinepak over a decade ago.
  • Jason Hunter
    December 13, 2005 at 4:15 pm
    Never did find out the cause of the problem with Cleaner and 19GB file. We ended up exporting out a QT reference file from our Symphony and then encoded that in Cleaner. We stuck with the video codec, despite its nickname, since that it was the client needed.
    Cleaner did a good job with it; I wish I had thought of this solution earlier.
    -Jason
