Activity Forums Apple Motion File size images limited to 4096?
  • File size images limited to 4096?
    Posted by Michael North on September 13, 2008 at 3:53 am
    I tried to use a large panorama, created from tiling multiple shots, taken with my Nikon SLR.
    I was totally stunned when a dialog box popped up, stating that the image exceeded the allowable size and would be reduced to 4096 … what!??
    I’ve only had Studio 2 for a few days …
    But I was hoping that the FCP/Motion combination would make After Effects superfluous …
    … but that doesn’t look like it’s going to happen …
    As it turned out, I ended up using Lightwave.
    I couldn’t get enough resolution out of Motion.
    and I couldn’t get the camera and camera-target controls to work smoothly enough in After Effects
    Because the things I do in Lightwave are so simple (images on cards)
    I was hoping to start doing many of them in a motion graphics program.
    But if the largest element is restricted to 4096 …
    Is there (I hope) something I’m not understanding?
    Does Motion just need way more memory? (I’m using 6 gigs)
    … a work-a-round maybe?
    Michael North replied 17 years, 11 months ago 2 Members · 3 Replies
  • Michael North
    September 14, 2008 at 4:50 pm
    Here is the exact quote from the dialog box:
    “This media is too large to render at full resolution, and will be shown at a lower quality.
    The maximum size is 4096×4096”
    The project itself will output at 1920×1080.
    I only need that much of the back drop showing, at any one time.
    I’m I miss reading this dialog box?
    Can I get the full resolution (all the detail) of my panorama when I move the camera across it?
    I’m running a three way test right now with Motion vs Aftereffects vs Lightwave.
    Lightwave seems to be kicking everyones butt … but
    It’s a -bunch- of extra steps, files and rendering time.
    Motion is totally new to me … so
    I’m mostly thrashing around on it. Can’t seem to get a camera-target.
    And the perspective view seem to only give me -one- perspective
    AfterEffects is an old friend … but I’ve never used the
    camera for 3D effects and can’t seem to get a perspective view at all.
    What I’m doing is very very simple.
    I just want to move a 1920×1080 window/viewpoint
    around a very large (16000×3000) panorama …
    But I need to squeeze every last bit of detail out of the large Photoshop file …
    OK … I got that off my chest … back to testing 🙂
  • Bryan Banks
    September 16, 2008 at 4:14 am
    have you tried splicing the large photo into tiles and then arranging them inside Motion and doing each of the moves with the camera inside Motion?
    -Bryan
  • Michael North
    September 17, 2008 at 2:32 am
    Yea … as it turned out:
    A couple of days ago, I did -just that- in AfterEffects with an extremely large 360
    that was too big for even Photoshop.
    I thought for sure that I would get seams that would prove impossible to work around.
    But … to my surprise … I was able to piece them (and keep them) perfectly together.
    So … today I went back to the Motion Project I’d been testing with and split the panorama, that Motion had been objecting about, into three pieces of 4000px. And sure enough, I was also able to put them back together seamlessly …
    The output looks great.
    The more time I spend in Motion the more I like it …
    I’m starting to feel at home with the “Way” of the program.
    But I’m also starting to get the feeling that it really wants about 20 gigs of ram :o)
    Thanks for the reply
