Activity › Forums › Adobe After Effects › File Size got increased after exporting AEP file to mp4 using Media Encoder.
  • File Size got increased after exporting AEP file to mp4 using Media Encoder.
    Posted by Suresh Balasubramaniyan on May 8, 2020 at 2:49 pm
    While i export aep file to mp4, through media encoder, file size was increased nearly like 1 GB, as aep file is just 500 KB only, what’s wrong in this, even i haven’t load any big media files in it.
    John Cuevas replied 6 years, 4 months ago 2 Members · 1 Reply
  • John Cuevas
    May 8, 2020 at 7:00 pm
    The .aep file is just your AE project file. At its more basic, it’s a database that keeps track of your assets, how you use them in a composition and the effects you layer on top of them, it’s generally going to be small. The mp4 is the output. Factors like composition size 1920×1080, frame rate, bit rate and complexity of each frame all contribute to the final size of the mp4.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
