Activity › Forums › Compression Techniques › File size from 49.4mb to under 10mb using compressor…any chance?
  • File size from 49.4mb to under 10mb using compressor…any chance?
    Posted by Sam Waldron on September 7, 2011 at 1:04 pm
    Hi there folks,
    I am using compressor to try and get this short video https://www.vimeo.com/24415806
    to a size of 10mb or less. I am using Compressor I have managed to get it down to about 26mb using settings where the quality is minimal for everything possible.
    I have taken downloaded the video from Vimeo as I no longer have the original file to work with nor the original sequence. Lesson learnt!!!
    Any help would be greatly appreciated.
    Kind Regards
    Sam
    Sam Waldron
    Final Cut Pro 6.0.6
    imac 4gb 1tb
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Sam Waldron replied 15 years ago 2 Members · 2 Replies
  • Craig Seeman
    September 7, 2011 at 1:40 pm
    It’s very simple math. Data rate and duration is file size.
    As you lower the data rate and the quality deteriorates your next option would be lower the frame size.
    Some would lower the frame rate be to me that’s a major temporal motion quality loss.
  • Sam Waldron
    September 8, 2011 at 7:03 pm
    Hi there, thanks for the answer, I tried it and never got below 10mb only 10.4mb. The quality was horrible.
    Sorted out in the end though, client was happy to go with quality rather than size. 🙂
    Thank you again.
    Sam
    Sam Waldron
    Final Cut Pro 6.0.6
    imac 4gb 1tb
