Activity Forums VEGAS Pro File Render, Annoying Error
  • File Render, Annoying Error
    Posted by Tyson Onaga on September 20, 2011 at 5:18 pm
    Has anybody received:
    An error occured while creating the media file.
    The file name is not valid.
    when doing File Render (Vegas 10).
    The name is Untitled.
    The format could be mpg, mp4, wav, etc.
    This is !)(@*&!)(*@&) (*& annoying …
    Tyson Onaga replied 14 years, 11 months ago 2 Members · 4 Replies
  • Mike Kujbida
    September 20, 2011 at 5:24 pm
    Give the file a name and see if you still get that error.
  • Tyson Onaga
    September 20, 2011 at 5:37 pm
    It doesn’t matter what the file name is. I tried everything from long file names to foobar. Even Untitled doesn’t work. And this happens sporadically and I have no idea why. I can’t find a pattern that reproduces it either. Shutting down and restarting Vegas mostly works.
    It is just !@)!*(_*( bloody annoying.
  • Mike Kujbida
    September 20, 2011 at 6:47 pm
    Time to go back to square one.
    What OS, what CPU, how much RAM, how many hard drives, what version of Vegas (Pro or Movie Studio), what version of DVDA, what’s on the timeline (stills, video & type of file), how long is the project?
  • Tyson Onaga
    September 21, 2011 at 5:44 am
    Found the issue. Apparently, if you start with a blank unsaved workspace, you can’t Render As without getting that error. I was trying to do a quick audio edit and dropped a wav file into a blank project. Render As always gives the error. If I open a “blank” saved project and do the audio edit there (don’t save it) the error doesn’t happen.
