Activity › Forums › Adobe Premiere Pro › File renaming bug
  • File renaming bug
    Posted by Vince Becquiot on February 20, 2009 at 6:37 am
    Working with CS4 on Vista 64. I recently found an annoying bug that kept me from renaming files in the project panel. The problem seems to occur when the name column is extended beyond a certain point.
    The solution was simply to drag the column back to a narrower size.
    Hope this can help someone with that issue.
    Vince Becquiot replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
