Activity Forums Adobe After Effects File Recovery
  • File Recovery
    Posted by Diametergirl on June 6, 2005 at 1:48 pm
    Anyone know of a good recovery program that I can use on an After Effects file that was damaged during a crash? I kept getting memory errors…and then crash… now, not only will my working file not open, but my back-up files are damaged also…any advice?
    Temidayo Lawal replied 8 years, 12 months ago 11 Members · 13 Replies
  • 13 Replies
  • Steve Roberts
    June 6, 2005 at 2:11 pm
    Have you tried importing the corrupt file into another AEP? If that doesn’t work, sometimes Adobe techs watch the Adobe forums and I’ve seen them take corrupt files and fix them … sometimes. 🙂
    Strange that your backups were damaged. Have you tried deleting AE’s prefs, or uninstalling/reinstalling?
    Steve
  • Diametergirl
    June 6, 2005 at 2:19 pm
    Hi Steve-
    Yea, I tried re-installing everything,importing into a new AEP, I cached the prefs., uninstalled all plugins, re-installed them again…I am at a loss. I thought it was wierd when my back-up files were damaged too, but I think that the entire working directory was some how damaged in “the great crash of 2005” instead of just the AE file I was working…which is why my other file got damaged. ALthough it is weird that only the AE files were affected.
    Have you ever used a recovery program on an After Effects file though? I heard that they aren’t recovered properly due to the format.
    I will try the Adobe forums, thanks for that…hopefully they can help.
    Any other suggestions…toss ’em at me!
  • Steve Roberts
    June 6, 2005 at 2:35 pm
    Sorry, I’ve never heard of a recovery program for AE.
    Good luck …
    Steve
  • Lukas Boeck
    September 22, 2011 at 12:25 am
    years later another suggestion for disgruntled googlers…
    yeah AE just crapped out on me, no luck with re-importing project file.
    then i thought that the machine basically saves another file anytime i hit ctrl+s, and that that doesn’t necessarily have to be on the same spot on the disk… threw a recovery software at the frigger, searching for deleted and lost files. voilà, got a previous version of the project a couple of hours old…
    also i find it interesting that it’s allways crapware makers like adobe who don’t enable automatic backups by default. probaly to give their programs an air of stability.
    oh why can’t all be avid?
  • Mitch Rosefelt
    March 13, 2012 at 5:57 pm
    Could you pass along the name of the recovery software you used? It will be GREATLY APPRECIATED!!
  • Lukas Nilsson
    April 26, 2012 at 1:02 pm
    Thanks for the tip, it worked! (Windows 7)
    The recovery software I used was: Recuva v1.42.544 its free and worked extremely well for me. Small install and easy to use. I just told it too look in the same folder as the corrupt aep file. After “deep scan” Recuva presented me with a list of all previously saved versions of the file(ie the same file but diferent save times). I recovered a few of the files just to make sure.
  • Nicole Kipp
    April 30, 2012 at 3:31 pm
    File recovery is a really important feature to be able to utilize. If you haven’t set up a file backup system after this has happened I highly recommend you do. I use File Fort as a backup if you are looking for something to get going with.
  • Nicolas Jullien
    August 29, 2013 at 8:52 am
    Amazing Lukas, I managed to recover my damaged after effect project in two clicks.
    You saved my day!
    xx
    nico
  • Silus Mihai
    October 28, 2014 at 8:17 pm
    How did you do it? I Cleared my AE cache files and one project is now corrupted, and I really need to recover it….
  • Darren Keith
    April 30, 2015 at 4:09 pm
    Hi Lukas. I have a corrupted AEP project that was overwritten. I am on a Mac and do not have access to the Window program you used to fix your corruption. I am getting ‘End of file’ errors on a Data Rescue recovery. Any chance you can look at my file to see if it can be fixed?
    Thank you
    DK
