Activity Forums Adobe Premiere Pro file numbering in premiere pro 1.5
  • file numbering in premiere pro 1.5
    Posted by François Bruyère on August 14, 2006 at 9:19 am
    Could someone help me with a tip concerning the numbering in premiere Pro 1.5. How can I arrange the numbering so that the files stay in order and not get mixt up?
    Aanarav Sareen replied 20 years ago 3 Members · 2 Replies
  • Jeff Bellune
    August 14, 2006 at 11:12 am
    Are you trying to import an image sequence? If so, when the import dialog opens, select only the first image in the sequence and then check the “Numbered Stills” checkbox.
    If your’re trying to do something else, please explain with more details.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Aanarav Sareen
    August 14, 2006 at 2:32 pm
    If I understand correctly, clicking on the name column should auto-arrange the files.
    Aanarav Sareen
    premiere@asvideoproductions.com
