Activity › Forums › Adobe Illustrator › File not readable
  • Bjorn Fagertun
    November 14, 2013 at 8:07 pm
    I found one way to work around, and that was to open the tiff-file in PS and save it as .eps
  • Jonathan Ziegler
    November 15, 2013 at 1:28 pm
    It depends on the TIFF. The likely culprits are that the compression (if used) is bad or the file is otherwise corrupt. Could also be the file was saved with a legacy formatting (doubtful). If it won’t open in AI, but it will in PS, it was likely corrupt in some way, but AI isn’t as robust as Photoshop when it comes to raster files anyway.
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
