Activity Forums Adobe After Effects file not found..
  • file not found..
    Posted by Ash Davis on April 28, 2010 at 1:20 pm
    I organised some image files that I’m using in AE, not realising it would mess up in AE on the ones I used. I put the files back to where they were originally but AE is still saying it can’t find them, how do I get it to locate them?
    Ash Davis replied 16 years, 4 months ago 2 Members · 2 Replies
  • Dave Johnson
    April 28, 2010 at 1:58 pm
    If both the file names and location paths are exactly the same as they originally were, AE will find the files when you close and reopen the project.
    If both the file names and location paths are not exactly the same as they originally were, you’ll need to right click each missing file in the AE project window, select “replace footage” and navigate to the appropriate file on your hard drive.
  • Ash Davis
    April 28, 2010 at 2:01 pm
    Thank you, I’ll try that..
