Activity Forums Apple Final Cut Pro Legacy File not found – Error: Out of Memory
  • File not found – Error: Out of Memory
    Posted by Mark Albertin on April 24, 2005 at 2:26 pm
    Dear FCP users,
    I’m working on a relatively small project (10 min.) in FCP 4.5. Everything has been going well. Then three-quarters of the way through I started having an error: “file not found – Error: Out of Memory” apprear everytime I tried to open any item in my timeline. It could be stills or video…nothing responds. Then when I close and restart I can’t even open the sequence. FCP starts up fine but not the sequence.
    I’ve deleted my prefs., optimized the drives and still no luck. Has anyone had this problem before? Can anyone please help me?
    Red-eyed and worn-out FCP user
    Chris Love replied 15 years, 8 months ago 4 Members · 6 Replies
  • David Bogie
    April 24, 2005 at 4:45 pm
    You can search the forum for those terms, you will find some interesting reading.
    Are you storing your media files on your system disk?
    If you’re not, then stop everything. Make backup copies of as much of everything as you can.
    Can you actually see the files in question on your media drive and in the scratch folder? Can you open them in QT?
    If not, stop everything and back up all you can.
    Run your drive utility apps on the media drives but DO NOT USE NORTON.
    Assume the worst case scenario: Your drive is failing or the directory has been trashed. Locate your original tapes because you may have to recapture everything.
    bogiesan
  • Mark Albertin
    April 24, 2005 at 5:24 pm
    I am storing my media files on separate firewire drives. Only the program file is on my system drive and that has been backed up.
    Yes, I can open any of the files in question in QT or photoshop (stills).
    So, I’m not going crazy yet…but I’m not holding my breathe.
    I’ve also already run Techtool Pro and everything comes out fine…not major problems.
    Any other ideas?
    Markus
  • Mel Matsuoka
    April 25, 2005 at 5:40 am
    I figured out that this error is caused by one of (at least) two things:
    1. FCP is trying to relink to a media/graphic file that it can see on
    the harddrive (or over the network–ya gotta be careful about NOT
    keeping network drives mounted when reconnecting media in FCP, because
    it will ofterntimes find matching media filenames on network mounts
    FIRST, which you may not notice if your Finder windows default to
    Column View), but doesn’t have Read permissions on said file.
    2. One or more media files are/have been corrupted somehow.
    The best solution I found is to use the Media Mangler to select the
    un-openable sequence in the Browser, then tell it to “Create Offline”,
    and UN-CHECK all the available options (delete unused media, etc), and
    to base new clipnames on existsing filenames. This will create a new
    project with the sequence, and a bin containing all the media in the
    sequence. You can then systematically go through your bin, and Make
    Offline media files one by one (leaving the media on the disk–DONT
    DELETE them!), until you are able to open the sequence without an
    error message. Then you can check the mediafile in question at the
    finder level and see if it’s either corrupted or has the wrong
    permissions set on it.
    Pain in the arse, but it works.
  • Mark Albertin
    April 25, 2005 at 11:38 am
    Thanks Mel,
    As you can imagine, this always happens at the worst possible time. Three quarters of the way through a project…almost finished, late at night and then…what in the heck is going on?
    Everytime this happened it was when I was right around a Photoshop PSD in my sequence. I can’t be for sure on this, but I suspect it could be the problem. I’ve found myself inching along with my project…work awhile, burn a quick tape copy of what is done and saving the project file with a differnt name constantly. Once this starts happening it gets to the point that if I close the sequence it will not open. The message appears and I can’t get back to where I was before. Very frustrating.
    I was also given a bunch of Powerpoint files from a third party…I’m going to see about those first thing this morning.
    Thanks again for your help.
    Markus
  • David Bogie
    April 25, 2005 at 2:42 pm
    Mel, this is probably the ONLY practical use of Media Manager I’ve ever seen around here.
    Great advice, good suggestion and excellent detective work on possible file location/naming issues. Hope it helps in this situation.
    bogiesan
  • Chris Love
    January 14, 2011 at 9:12 pm
    Same problem. Searched all day and finally found your advice Mel. IT WORKED! After seeing lots of posts blaming stills and photoshop files, I was surprised to find that my corrupt file was a DV file. Although the nested sequences, still images and photoshop files in my project do load slowly, they were not to blame.
    Almost six years after you originally posted, it’s still helping out people like me. Thanks.
