Activity › Forums › Adobe Encore DVD › File Not Found Error on preview and build
  • File Not Found Error on preview and build
    Posted by Ray Lupton on August 3, 2010 at 3:44 pm
    Hi
    I’m getting an error whenever I try and preview or build a disk or an image. It seems that Encore CS5 is using old preview files. Is there any way to clean these up safely or a solution to this isse.
    Minu Sharma replied 16 years, 1 month ago 2 Members · 1 Reply
  • Minu Sharma
    August 6, 2010 at 5:38 am
    Hi Ray ,
    just check whether all your files in the project online , if there is any media offline file present in the project , there is a possibility of this file not found error while building and preview.
    Please check your project and if you find any media offline , locate source asset or locate to transcoded file(if present in transcode folder)
    Minu
