Activity › Forums › Apple Final Cut Pro Legacy › File Naming From Master mxf file to QT file via FCP 6
Jim Calahan replied 17 years, 11 months ago 4 Members · 14 Replies
Bjoern Adamski
October 5, 2008 at 5:19 pmYou can go through the website, our system sends a notification to the entire team so I can send you a direct reply.
Bjoern———————
Product Manager
MXF4mac
https://mxf4mac.com -
Bjoern Adamski
October 5, 2008 at 5:58 pm -
Jim Calahan
October 5, 2008 at 6:17 pmMedia100 and FCP will play with the same files as long as the codecs are in the quicktime folder. Media100 would separate the audio files out but in this case QT is just a wrapper so quality isn’t affected unless you convert it into one of Media100’s codecs. Both programs could run on the same Mac if loaded onto different boot partitions or drives because of driver conflicts with hardware.
Jim Calahan
KVIE, Sacramento
