Activity Forums Apple Final Cut Pro File naming
  • File naming
    Posted by Zeina Aboulhosn on December 26, 2019 at 11:47 am
    Hi, I am about to start an edit on FCPX and I have a concern about the naming of the files on the harddrive and how that might impact the workflow.
    1. The shoot was over many years with multiple cameras, mainly Canon 300, so there are many files named ‘C0001’ or ‘C0002’, from multiple shoots over the years… They are however in separate folders and subfolders on the harddrive. Will this cause a problem later? Will clips link to the wrong files? I don’t think changing the file names is acceptable anyway as they are the files created by the camera…
    2. For some of the footage taken on mobile phones, the director changed the names of the files to actual descriptions rather than numbers – so for example ‘nicole at the beach.mov’ or ‘rain in the mountains.mov’ ) including spaces… Can I import them like that or should I rename/number them?
    Zeina
    Zeina Aboulhosn replied 6 years, 8 months ago 4 Members · 4 Replies
  • Michael Hancock
    December 26, 2019 at 4:36 pm
    1. Do not rename the Canon 300 files. Keep the folder structures intact exactly as they are, and FCPX should be able to differentiate between them using additional metadata (like timecode). Renaming files can sometimes break metadata links within camera card structures, which can make it difficult or impossible to properly relink if needed.
    2. I wouldn’t bother renaming any of the mobile phone clips that the director has already renamed. Just use them as they are and you can rename then in FCPX.
    Michael Hancock
    Editor
  • Brad Hurley
    December 26, 2019 at 5:59 pm
    A useful distinction to keep in mind is file names versus clip names. File names are the names set by the camera; these are what you will see on your hard drive or other storage media. Clip names are names you assign to clips within your NLE; renaming a clip using FCPX’s inspector does not change the file name but instead creates a clip name within FCPX that is more descriptive or informative.
    That said, it’s probably not worth the time to rename clips within FCPX. Consider assigning keywords instead, which will allow you to use smart keyword collections and filtering to find the clips you’re looking for. That’s much more efficient than searching through clip names. If you want to add more detailed descriptions (which are also searchable) you can use the “Notes” field in the inspector. The combination of keywords and favorites is very powerful in FCPX.
  • Joe Marler
    December 26, 2019 at 10:18 pm
    [Zeina Aboulhosn] ” I have a concern about the naming of the files on the harddrive and how that might impact the workflow.
    1. The shoot was over many years with multiple cameras, mainly Canon 300, so there are many files named ‘C0001’ or ‘C0002’, from multiple shoots over the years… They are however in separate folders and subfolders on the harddrive. Will this cause a problem later?”
    Yes this can definitely cause a problem. Under no conditions import a bunch of files with duplicate names – even if they are in separate folders. There is a bug in FCPX which will create spurious duplicates due to a database problem if you ever load an XML referencing those files. I reported this to Apple long ago and it’s still not fixed.
    Besides this it streamlines post production if you have globally unique filenames. There are many situations where you may collaborate with other post-production people. It is a constant source of confusion to have many files with the same name. I cannot count the number of times I’ve had to explain “I meant the c0003.mp4 file size 1.56 GB with creation date 14-Nov, not the one size 1.42 GB with creation date 13-Nov”. Redundant filenames (even if in separate folders) is often confusing, wastes time and is error prone.
    It is not difficult to avoid duplicate filenames. Simply rename the files to be globally unique before import to FCPX. I use the 3rd party tool “A Better Finder Rename” https://www.publicspace.net/ABetterFinderRename/index.html
    However Finder itself has batch rename ability. You can even do multiple rename passes to achieve your goals. Gary at MacMost Now just did a tutorial on this feature: https://macmost.com/step-by-step-using-the-mac-batch-rename-tool.html
    My documentary team simply appends an incrementing 5-digit serial number to each file as part of the offload process. We keep track of the highest number used then the next offload operation uses the next sequential number. That way no matter how many projects or cameras, the filenames are unique.
  • Zeina Aboulhosn
    December 27, 2019 at 8:55 am
    Thanks to everyone who replied, super helpful
