Activity Forums Adobe After Effects File Names
  • File Names
    Posted by Jason Ely on July 17, 2008 at 12:27 pm
    When ever I import a file with a long name it abbreviates it. I need the name as I want it to be the name of the comp. I tried typing it back in but it shortens it every time. Is there a setting to turn this off or is there a workaround. I basically need the file name to in turn be the comp name and in turn be the final output name. I need this to make the work flow fast and easy. Can you help?
    Jason Ely replied 18 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
