Activity Forums Apple Final Cut Pro Legacy file location
  • Posted by Rick Davis on October 14, 2009 at 2:00 pm
    This seems like a simple question but I’ve never been able to figure it out.
    When I’m trying to save a file,FCP will prompt with the questions “Save as” and “Where”. When I look at the drop down menu on the “Where” window I’m offered all of my drives and “recent places”. My question is, how do I select and locate a specific folder within one of my hard drives to store the file within?
    I’m using FCP vers 5.1.2. I have 2 internal drives and an external RAID.
    Thanks for you help.
    Rick Davis replied 16 years, 11 months ago 3 Members · 4 Replies
  • Alvin Bicasan
    October 14, 2009 at 3:00 pm
    “I’m offered all of my drives and “recent places”
    Once you see all your drives on the save as window, you should just click on the appropriate drive and folder to specify exactly where you want to put the file.
    Alvin
    FCP 6.x.x on OSX
    MacPro Intel Nehalem Quad 2.93 GHz 16RAM
    ATI Radeon 4870 512VRAM
    System Drive 1TB Internal WD Caviar Black 7200rpm
    Media Drive 1TB Internal WD Caviar Black 7200rpm
  • Rick Davis
    October 14, 2009 at 3:28 pm
    Hi Alvin,
    That’s the problem, when I select the drive it doesn’t open up that drive to allow me to place it in a folder or sub-folder. It just stays with the hard drive name only. What am I missing here?
    Thnx.
  • John Fishback
    October 14, 2009 at 9:49 pm
    Sorry to state the obvious, but you are double-clicking right? If you simply use the finder, can you open and see folders within your various drives? If so, try trashing FCP prefs and repairing permissions. If not, your OS might be corrupt (but try repairing permissions before doing anything radical). Also, it never hurts to run Disk Warrior.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Rick Davis
    October 14, 2009 at 10:44 pm
    Thanks John, I’ll trying trashing prefs & repairing permissions first.
