Activity Forums VEGAS Pro File is corrupt or an unknown format
  • File is corrupt or an unknown format
    Posted by Whit Prophet on August 24, 2017 at 11:12 am
    Hi
    I have tried importing a file and get the error message, File is corrupt or an unknown format.
    I can play the video with WMP and I can import it in Cyberlink Power Director, but it will not import into Vegas Pro 14.
    Any suggestions for an approach to solving this?
    The file is available here if someone would have the time to download and attempt loading it.
    Here is a link to download a game: https://www.dropbox.com/s/ysuaie6bg3zs4ao/NS%20Vs%20Vees%20ViPr%20Scorebar.mp4?dl=0
    I am afraid all my video this upcoming season will be like this and my hands will be tied.
    Whit
    Aaron Star replied 9 years ago 2 Members · 2 Replies
  • Whit Prophet
    August 24, 2017 at 9:02 pm
    Further info:
    The video is a stitched output of a Pixellot camera.
    Here is the MediaInfo data on the file:
    Encoded date : UTC 2017-05-26 16:18:53
    Tagged date : UTC 2017-05-26 16:18:53
    Writing application : vlc 2.2.4 stream output
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, RefFrames : 4 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 1 h 59 min
    Bit rate : 1 503 kb/s
    Width : 1 280 pixels
    Height : 738 pixels
    Original height : 720 pixels
    Display aspect ratio : 1.734
    Original display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 24.973 FPS
    Minimum frame rate : 1.389 FPS
    Maximum frame rate : 25.000 FPS
    Original frame rate : 25.000 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.064
    Stream size : 1.26 GiB (88%)
    Language : English
    mdhd_Duration : 2884633
    Audio
    Format : mp3
    Codec ID : 0
    Source duration : 1 h 59 min
    Bit rate mode : Variable
    Bit rate : 192 kb/s
    Maximum bit rate : 4 347 kb/s
    Channel(s) : 2 channels
    Sampling rate : 44.1 kHz
    Bit depth : 16 bits
    Stream size : 164 MiB (11%)
    Source stream size : 164 MiB (11%)
    Language : English
    mdhd_Duration : 7179771
  • Aaron Star
    August 25, 2017 at 7:55 am
    Some odd things about the format:
    Height : 738 pixels
    That’s an odd video format for hardware to be writing.
    I would try re-encoding it with Handbrake or FFMPEG (if you know command line.)
