Activity Forums VEGAS Pro File IO Surragate in Task Manager Crashes Sony When Task Ends
  • File IO Surragate in Task Manager Crashes Sony When Task Ends
    Posted by Debbie King on May 19, 2015 at 12:27 pm
    Hi Everyone:
    I am trying to remove File IO Surrogate from my Task Manager from Processes. When I click End Task, it crashes my Sony. This never a happened before and I am wondering if I have a larger issue. Has this ever happen to you?
    I was rendering DNxHD and all was going smoothly, except I was having some sync issues and would attempt to render after file modification. My last render had lots of flickering so I searched everywhere to see if I could find the problem. When I looked in Task Manager I saw File IO Surrogate. Any help would be greatly appreciated.
    Many thanks,
    Debbie
    PS: I did update my Norton last night. My rendering has been different since. I deactivate everything when I render; that is, Internet and other specific Task Manager processes. I also deactivate Windows and Norton updates also.
    Debbie King replied 11 years, 4 months ago 3 Members · 3 Replies
  • Norman Black
    May 19, 2015 at 4:48 pm
    FileIoSurrogate is a process used by Sony Vegas to interface with 32-bit codecs. Quicktime is always 32-bit.
    If you terminate FileIoSurrogate while Vegas is running, then Vegas is not going to like this as you have found out.
  • Steve Rhoden
    May 19, 2015 at 4:59 pm
    No, don’t delete File IO Surrogate while Vegas is running, its part of it’s
    processing, so that’s why it crashes.
    Norton is a death trap, you shouldn’t even have it installed on your editing
    system, i stay far away from anything Norton and advise everyone accordingly.
    And the fact that things start behaving oddly since you update it, is a clear
    sign and deactivating it alone wont help.
    There are other far less intrusive and resource hogging Antivirus out there.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Debbie King
    May 23, 2015 at 4:29 am
    Hi Steve and Norman:
    Thank you so much. It’s a relief to know this.
    Many thanks!
    Best,
    Debbie
