Activity Forums Apple Final Cut Pro Legacy File I/O Error
  • Posted by Calvideo on April 21, 2005 at 5:00 am
    When I try to export my FCP 4.5 sequences to Quicktime movie, self-contained or not, the process begins but is aborted and I get the File I/O Error message. Then, if I try to use compressor, the same error message invariably appears and the process is aborted. My work-a-round has been to play the sequence, copy it to DV tape, then re-capture the edited sequence and that will then convert to a Quicktime movie, no problem. But it is unsatisfactory. Does anyone have a better suggestion than to just recapture all the original footage? Thank you for your help.
    Calvideo replied 21 years, 5 months ago 2 Members · 2 Replies
  • Sean Oneil
    April 21, 2005 at 5:59 am
    Repair disk permissions.
  • Calvideo
    April 21, 2005 at 7:40 pm
    Thank you very much, Sean, it worked!
