Activity Forums Apple Final Cut Pro Legacy File I/O Error-jerk
  • File I/O Error-jerk
    Posted by Willy Lavendel on December 2, 2010 at 2:14 am
    Hello all,
    I’ve been editing for over 6 years and have never heard about this error. I’ve used my 1st external without ever receiving it. I’ve used my current external for over a year without receiving it, until now. A day earlier I exported just fine, the same way I always do, and now all of a sudden here it is.
    I checked to see if it was a corrupt file or sequence using the FCS Maintenance pack and it found some files, I deleted them, etc and it still came up.
    So is the only answer to buy a new external and format it to FAT32 or is there another way? If that is the case then why would it happen all of a sudden? Is that just the doom we all will encounter when using fickle, temperamental non-SSD’s?
    Willy Lavendel
    “Is this for real?” “No, only in the movies”
    Willy Lavendel replied 15 years, 9 months ago 3 Members · 6 Replies
  • Jerry Hofmann
    December 2, 2010 at 2:07 pm
    If I read this right, you’re using the wrong formatting for the drives. Should be Mac OS extended.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Jeremy Garchow
    December 2, 2010 at 4:28 pm
    Yeah, why format your drives for anything but a Mac?
    You want OSX Extended journaled.
  • Willy Lavendel
    December 3, 2010 at 8:29 pm
    I double-checked the info and the drive I’m using is Mac OSX journaled.
    Like I said, it was exporting fine and all of a sudden it had the file.
    Willy
    Willy Lavendel
  • Willy Lavendel
    December 3, 2010 at 11:40 pm
    Ok. I know now that it is just one project that won’t export, others are fine, my external is fine. Good.
    I noticed that there are some dropped frames in my project, could that be the file I/O error?
    If so, I’ve tried some techniques to beat the dropped frames but to no avail, any ideas?
    Thanks you guys
    Willy
    Willy Lavendel
  • Jerry Hofmann
    December 4, 2010 at 2:38 am
    Sounds like a corrupt file in there somewhere…
    Jerry
    Current DVD:
  • Willy Lavendel
    December 8, 2010 at 1:35 am
    Right, that is what I thought and I ran a corrupt file scan. I’ve even trashed the prefs and done a whole bunch of other RT adjustments.
    Do I need to increase the speed of my drives? It hasn’t been a problem before and it works fine on other projects.
    Any other ideas?
    Willy
    Willy Lavendel
