Activity › Forums › Apple Final Cut Pro Legacy › File I/O Error
File I/O Error
Posted by Bob Davis on August 7, 2008 at 9:00 pmLast month I added a 2nd GSpeed-es 2tb drive to my Mac Pro/FCP system. It is configured in Raid 5.
I haven’t had any problems until yesterday. While editing in FCP I tried to render a clip and got the File I/O error message. There was nothing wrong with the clip as I had rendered it in the timeline moments earlier w/o any problems.
I also got the same message in Soundtrack Pro… so what do I need to do to track this down and resolve the issue.
Bob Davis
dp Davis ProductionsBob Davis replied 18 years ago 3 Members · 11 Replies -
Michael Gossen
August 8, 2008 at 1:28 amPermissions maybe? Check to see if you are ignoring permissions on the volume with ‘Get Info’ (Apple+I).
Michael Gossen
Helium Digital Media -
Bob Davis
August 8, 2008 at 1:53 amNope that wasn’t it. The drive has Read & Write permission…any other ideas….
Michael Gossen
August 8, 2008 at 2:10 am -
Bob Davis
August 8, 2008 at 2:24 amRan Disk Utility and got this:
Verify and Repair disk “dp 01”
Checking HFS Plus volume.
Checking Extents Overflow file.
Checking Catalog file.
Invalid sibling link
Volume check failed.Error: The underlying task reported failure on exit
1 HFS volume checked
1 volume could not be repaired because of an errorNow if I only knew what that all means….
Michael Gossen
August 8, 2008 at 2:45 amThere you go. Copy everything off, repartition the drive using disk utility. Name the new partition the exact same as now and when you copy everything back you shouldn’t have any reconnection issues.
Michael Gossen
Michael Gossen
August 8, 2008 at 2:47 amThere you go. Copy everything off, repartition the drive using disk utility. Name the new partition the exact same as now and when you copy everything back you shouldn’t have any reconnection issues.
Michael Gossen
Michael Gossen
Michael Gossen
Michael Gossen
Michael Gossen
Bob Davis
August 8, 2008 at 4:09 amOh, if I only had a spare TB of disk space to dump everything to….
Thanks for your help….
Bob Davis
David Roth weiss
August 8, 2008 at 4:34 amBob,
Having paid $1000 per gigabyte at the start of digital revolution, I will let no one who complains about inadequate disk space these days escape here unscathed. So, consider yourself therefore duly scathed.
Now, tomorrow go out and spend $160 and get yourself a 1Tb drive and a cheap firewire enclosure at Fryes, please.
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
