Activity › Forums › Apple Final Cut Pro Legacy › File I/O error.
File I/O error.
Posted by Steve Cohen on March 29, 2007 at 12:44 amI just started getting File I/O errors on my 320GB G-Raid when I goto render something and the drive is responding very slow.
I’ll get the spinning ball for about 2 min and then it will play the timeline.
I say it’s my G-raid, because when I play a project off of my 500GB Lacie everything seems fine.
Help. I have a deadline to finish tonight.
Steve Cohen
Editor
O2 Media Inc.Felipe Carrelli replied 11 years, 6 months ago 6 Members · 7 Replies -
Sarah Adina smith
November 28, 2007 at 6:07 pmDid you ever figure out what to do? I’m having the same problem working off of a maxtor 750 gig and a maxtor 250 gig . . .
Steve Cohen
November 29, 2007 at 12:20 amI hope this is not the case in your situation, but it turned out that my G-Raid was failing.
I actually lost the entire drive, but it was under warranty and G-Tech repaired it.Didn’t help with the project though.
Better luck to you.
Steve Cohen
Editor
O2 Media Inc. -
Sarah Adina smith
November 29, 2007 at 12:25 amThanks Steve –
So . . . it took a bit of playing around (albeit, mostly random) . . . but I think I’m back to being okay. After I repaired my disk persmissions, I restarted my computer a few times while playing around with using different firewire cords . . .
Not sure if it will happened again in the future . . . crossing my fingers.
Its a scary error, though . . . demons and evil.
Sorry about your project, that’s heart wrenching
Sarah
Nadiyah Skyy
December 6, 2007 at 2:49 pmI am having the same problem with a Western Digital 320 GB “My Book”. I’m not sure if it is the recent updates to Final Cut Studio 2 or my hard drive but I need any suggestions.
Sean Hunter
February 7, 2008 at 7:29 pmI’m having the exact same problems with my project. I was almost halfway done editing my project without any problems and then all of a sudden whenever I click on or try to play my timeline it will play for a few seconds and then freeze and then the spinning ball will appear and I will be forced to Force Quit. I do not want to just abandon this project, and this is a brand new hardrive with only this project on it. The Western Digital 320 GB “My Book”. Can anyone offer any help?
Josh Hayes
July 1, 2011 at 6:45 pmI’m sure there’s different reasons for some people, but I figured out what was causing it on my end. The common factor most of us have is that these are new drives. And with new drives comes a bunch of new cables. I pulled the new firewire cable I was using (that had just come with my drive) and switched it with a firewire 800 cable I know worked, and wholla. Problem instantly solved!
Why does is always have to happen on a deadline?
Felipe Carrelli
March 11, 2015 at 2:09 pmMy problem was that I was using an WAV non compress file. After I change to mp3 audio file did not work. So i converted to AIFF and work fine! Hope it works for you too!
