Activity Forums Adobe Premiere Pro File Format Question again
  • File Format Question again
    Posted by Mike Prindle on January 6, 2010 at 5:17 pm
    Hi there,
    I have several .avi files – 1920×1200, 29.97 to import to Premiere CS4 and combine/edit; then create a high-res output file.
    I created a new project with Premiere preset: AVCHD 1080p30 (frame size: 1920×1080, 29.97fps, aspect=1, square pixels). After editing, I exported to Encoder (File > Export > Media). To best match my input files and get the high quality res, I chose Encoder Export Settings — Format: MPEG2 Blu-ray – Preset: HDTV 1080i 29.97 High Quality.
    The Encoder Summary box read: NTSC, 1920×1080, 29.97 drop frame[fps], Upper, Quality 4.0; Sound 48kHz, 16 bit, stereo PCM; VBR (variable bit rate), 1 Pass, min=25, target=30, max=35 Mbps. The output file became: filename.m2v
    The video portion was fine, but there was no audio. Does this format create a separate audio file like format MPEG2-DVD? I couldn’t find any separate audio file. Why no audio? I later created an AVI file and all was fine with that output file.
    And are there any suggestions for better settings that would achieve a hi-res output file as close as possible to the input files at 1920×1200?
    Mike
    _____________________________
    Sager NP-9262 Notebook, Intel Quad Q6600, 4GB DDR2, nVidia 8800m GTX, 3x-Seagate 500GB, WUXGA, Vista Premium-x64 – Production Premium Suite CS4
    Mike Prindle replied 16 years, 8 months ago 2 Members · 2 Replies
  • Mike Velte
    January 7, 2010 at 11:32 am
    .m2v is a video only file. Look for a .wav file with the same name.
  • Mike Prindle
    January 7, 2010 at 10:04 pm
    Thanks again Mike…. problem solved!! Appreciate it!
