Activity Forums Adobe Premiere Pro file format not supported
  • file format not supported
    Posted by Angela Elum on November 10, 2008 at 1:25 am
    I have Premeier CS3 and just purchased the book- “Adobe Premere Pro CS3 Classroom in a Book:. When I try to open up the first lesson, I get an error message that says:
    “File format not supported” – I’m trying to open Lesson1.prpoj. Can anyone assist me with this, I can’t even get pass step one.
    Luis Plata replied 17 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • Eddie Lotter
    November 10, 2008 at 2:30 pm
    What version of Apple QuickTime do you have installed?
    Cheers
    Eddie
  • Angela Elum
    November 10, 2008 at 11:35 pm
    I don’t currently have Apple Quicktime on my computer. Should I install it and if so what version. Thanks.
  • Eddie Lotter
    November 11, 2008 at 1:58 pm
    Yes, install the version that is available on the Apple Web site.
    Cheers
    Eddie
  • Angela Elum
    November 11, 2008 at 3:58 pm
    Yes that worked!!! I was able to open the files within the project. Thanks so much for all of your help.
  • Eddie Lotter
    November 11, 2008 at 5:17 pm
    You’re welcome. Happy editing. Happy editor
    Cheers
    Eddie
  • John Sullivan
    January 28, 2009 at 2:56 am
    Eddie or anyone who can help. I had the same problem as Angela, then I found this thread and installed Qiucktime. All was well for a few days, then as I moved to lesson 6 file format not supported reared its head again. I tried updating Quicktime, but this did not help. I ran the previous release of Quiktime from a shadow copy with no luck, I uninstalled and reinstalled Quicktime with no luck, I set Quicktime to have all defaults and customized the defaults both with no luck. Can anyone help? Thanx.
    J.
  • Eddie Lotter
    January 28, 2009 at 2:22 pm
    One of the links on this page will hopefully have the answer to your specific needs. Don’t ignore a link because the title doesn’t look relevant.
    Cheers
    Eddie
  • Luis Plata
    June 26, 2009 at 3:57 pm
    I had the same problem with the .mov files i kept getting “file not supported” and all i did is i right clicked on the adobe premiere icon and then properties and clicked off the “Run this program in compatibility mode for”. It used to be checked on windows xp mode.
