Activity Forums Adobe Premiere Pro File format not supported
  • File format not supported
    Posted by Alexandre Brandt on July 15, 2013 at 1:00 am
    Hello all,
    I’m just starting to use Adobe Premier pro, after having used for the last 7 years FCP.
    I have to do a switch from FCP and Premier pro seems a good options as I heard.
    However I’m already having trouble with very simple things 🙁
    I have some HDV media that was captured on CF card. It’s this in File base structure. I’d like to ingest that in Premier but when I do File->import -> i select the folder of the CF card (copies to a hard drive) a message pops up and tells me File format not supported. I read everywhere that HDV is supported by premier pro. I have my sequence preset set for HDV 1080p25 (its European footage) but I don’t know what to do. Can someone help me ?
    Thank you for reading !
    motion pictures + storytelling = ?
    -> FILMMAKING !
    Alexandre Brandt replied 13 years, 1 month ago 2 Members · 2 Replies
  • Chris Tompkins
    July 15, 2013 at 12:29 pm
    Try bringing it in by first ~ opening the media browser, then bring clips into project.
    Chris
  • Alexandre Brandt
    July 15, 2013 at 12:59 pm
    Yes sir. It works that way. Thanks Chris.
    -> FILMMAKING !
