File format for most used editting a effects sofware
Hey there,
I am exporting some projects out of my After Effects and wanted them to be compatible with most of the video editting softwares, such as Premiere and Final Cut in both pc and mac. I was thinking of using QuickTime movie using PNG for the compression and RGB+Alpha, for transparency and to keep the file size low and still have a good quality. Is it going to work fine or is there any other format that I could use??
Thank you very much,
Gabriel.
