Activity Forums Adobe Premiere Pro File format (AVC HD – too heavy)
  • File format (AVC HD – too heavy)
    Posted by Gonçalo Neves cruz on February 10, 2013 at 5:09 pm
    Hello, i have a Sony a57. It records on the file format AVCHD.
    When i’am editing the avc hd file on premire it’s so easy…
    i want to keep the high quality, but i wish to edit in a lighter file (like MPEG2, for exemple)
    should i put the AVCHD files on a time line and render them as mpeg2? What should i care for when changing the format?
    Gonçalo Neves cruz replied 13 years, 7 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    February 10, 2013 at 10:57 pm
    AVCHD isn’t a compression format, it’s just a branded mix of camera/recording media/file folder structure/tuned codecs.
    AVCHD is compressed using a high bitrate version of h.264 which makes it more suitable for editing than highly compressed web video which may be of the same compression scheme.
    I would probably install the Avid Quicktime codecs https://avid.force.com/pkb/articles/en_US/download/Avid-QuickTime-Codecs-LE-2-3-8 and export to Avid DNxHD (available in Premiere/Media encoder as a Quicktime video codec) as an intermediate file. It’s performance is similar to Apple ProRes.
    Unless you know what you’re doing, then setting mpeg2 encoding settings to be edit friendly can be a daunting task.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Gonçalo Neves cruz
    February 11, 2013 at 1:05 am
    [Angelo Lorenzo] “AVCHD isn’t a compression format, it’s just a branded mix of camera/recording media/file folder structure/tuned codecs.”
    That sure is complicated… Do you know where can i learn some more about it? I’ve always been intrigued about the history of formats and how and why they were created. I make use of them but sometimes i don’t know why… If you can, please send me a link (or even text me) about it.
    [Angelo Lorenzo] “AVCHD is compressed using a high bitrate version of h.264 which makes it more suitable for editing than highly compressed web video which may be of the same compression scheme.”
    Yes… I understand, but it’s still too laggy on my computer. Avi and Mpeg2 are way better.
    [Angelo Lorenzo] “I would probably install the Avid Quicktime codecs https://avid.force.com/pkb/articles/en_US/download/Avid-QuickTime-Codecs-LE-... and export to Avid DNxHD (available in Premiere/Media encoder as a Quicktime video codec) as an intermediate file. It’s performance is similar to Apple ProRes.”
    with this i would be creating a lighter copy of the AVCHD videos. Like Proxy editing? If that the case, wouldn’t it be better to save them to .Avi, edit and the replace footage? (sorry if i am not understanding what you meant and i’m just saying rubbish)
    [Angelo Lorenzo] “Unless you know what you’re doing, then setting mpeg2 encoding settings to be edit friendly can be a daunting task.”
    If i tell you the AVCHD properties would you be able to tell me what are the best mpeg2 properties to set in the export panel?
    Thanks for the answer
