Activity › Forums › Compression Techniques › File for preset ‘hq’ not found
Posted by Magnus Karlsson on May 17, 2011 at 5:55 pmHow come i get the following when trying to convert?
Michael Rampe replied 15 years, 3 months ago 2 Members · 1 Reply -
1 Reply
Michael Rampe
May 17, 2011 at 10:50 pm[Magnus Karlsson] “How come i get the following when trying to convert?
File for preset ‘hq’ not found”Was it working before and now not working or is this a first use error?
Could be a couple of things….
If you are using an *older* version:
The hq preset has been missing for some time now. Check the FFpresets folder for available preset options.If you are using a *newer* version:
The command line options changed recently for libx264. The -vpre option has been replaced by a method calling the x264 presets direct. -preset, -profile & -tune are the new options to replace the -vpre use. Check the x264 docs for a full list of available options.Can you post your command line and output to verify the error/version?
Michael
