Activity Forums Avid Media Composer File export size
  • File export size
    Posted by Gregory on August 1, 2005 at 12:36 pm
    hi there
    does anybody know why avid cannot make files larger then 2 giga if i try to make it quicktime animation. it says that i must change the Export settings, but i didnt found there anything that connected to the size of the final export file…
    thanks in advance
    zp
    R. Hewitt replied 21 years, 1 month ago 3 Members · 4 Replies
  • Carl Amoscato
    August 1, 2005 at 2:03 pm
    The 2gb limit applies to AVI files. Check your output settings and make sure you haven’t inadvertantly set the file type to AVI someplace.
    good luck,
    Carl
  • Gregory
    August 1, 2005 at 2:22 pm
    this isnt the problem
    quicktime movie
    custom
    format options—>animation—>millions of colors
    my movie is 12 min and i have 18gb free on my HD
    may its because the avid installation is on c: partition and the project is on d: partition
    but still i have the problem…
    i checked in avid forum and i saw that i m not the only one…
    do u have any suggestions?
    thanks a lotand i m not the only one
  • R. Hewitt
    August 1, 2005 at 3:34 pm
    As far as I’m aware there is a 2GB limit on Avid systems. The solution is normally to break the files down into smaller sections but that makes the export option a touch tricky.
  • R. Hewitt
    August 1, 2005 at 3:55 pm
    The following link may help identify the problem:
    Avid Knowledge Base.
