Activity Forums Apple Final Cut Pro Legacy !!!! File error: Unknown volume… on SAVE!!!!
  • !!!! File error: Unknown volume… on SAVE!!!!
    Posted by Aaron Neitz on June 3, 2005 at 6:21 pm
    I don’t want to lost my last 40 minutes of work…. Final Cut refuses to save my project ANYWHERE. Not on a local drive, not on a network drive, the autosaves are running into the same error. Opened a new project and dragged my sequences across, it won’t save that either.
    Phil Stone replied 21 years, 2 months ago 3 Members · 3 Replies
  • Arnie Schlissel
    June 3, 2005 at 8:41 pm
    First, I’d be willing to bet that you have a slash/ in your file name. Remove it & you’ll be fine. Unix does not like filenames with slashes in them. If you want, you can replace the slash with an underscore_ or a hyphen-.
    Second, you really need to save a lot more often than every 40 minutes. Personally, I reflexively save anytime I get something the way I like it, any time that I decide to go back & try something different, or any time I decide to change gears & move on. Autosave is not a replacement for being careful & methodical. The people who complain about autosave not working right are always the ones who go hours on end without saving their work.
    Arnie
    https://www.arniepix.com
  • Aaron Neitz
    June 3, 2005 at 9:18 pm
    whaddya mean “Autosave is not a replacement for being careful & methodical” ???
  • Phil Stone
    June 4, 2005 at 10:43 am
    Had the same problem – found out that when I had Apple works open and had printed or saved a document
    then went back to FCP I could not save to the internal drive – Workround save as to another drive close FCP
    re-open FCP then overwrite you existing poject.
    Do not open Apple Works whilst FCP is open.
    Hope this helps
