Activity › Forums › Apple Final Cut Pro Legacy › File Error: Unknown file – all the time in my FCP
  • File Error: Unknown file – all the time in my FCP
    Posted by Carlos Braun on September 23, 2013 at 2:59 am
    I am editing and when I try to render anything (right now audio cross fades) I can’t and the message “File Error: Unknown file” pops up. I had the same prpblem a couple of hours ago when I dragged some footage into the timeline… It asked to render (red line) and I got that message. I re converted all videos to 1720 X 980 in order to edit, but I realizeed the problem is probably on my FCP as now I can’t even render the dissolves without getting the same message. Any ideas?
    Carlos
    Ben Holmes replied 13 years ago 3 Members · 4 Replies
  • Shane Ross
    September 23, 2013 at 3:35 am
    FCP works with standard broadcast frame sizes. That isn’t one. 1920×1080…1280×720…those are HD frame sizes. Anything else will require a render.
    Also, FCP works with specific codecs only. For HD, the standard codec is ProRes 422. But for a full list, look in the Easy Setups in the Final Cut Pro menu. FCP will not work with H.264, MP4, or other highly compressed delivery format.
    Where did this footage come from? How did you convert it? And what did you convert it to?
    Shane
    Little Frog Post
  • Carlos Braun
    September 23, 2013 at 3:16 pm
    Thanks Shane. Actually the problem seems to be of a different nature. My FCP is not rendering anything, so it wasn’t really a problem with the video files. I cannot render audio transations, the same message (File Error: Unknown file) shows up.
    Carlos
  • Shane Ross
    September 23, 2013 at 5:16 pm
    Trash your preferences. PREFERENCE MANAGER from digitalrebellion.com will do this with one button click, and it’s free. Apple uses it.
    Shane
    Little Frog Post
  • Ben Holmes
    September 24, 2013 at 1:59 pm
    The location you set to send render files to, or the location you are using to save the project to probably does not exist. Have you ejected an external drive accidentally.
    FCP throws up this error if a volume goes offline. Check in your system settings in FCP, and also try saving the project to your desktop temporarily.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/community/communitydetails/?UserStoryId=8757
