Activity Forums Apple Final Cut Pro Legacy File Error: Unknown File.
  • File Error: Unknown File.
    Posted by Tim Allen on October 20, 2008 at 9:21 pm
    Hey Gang,
    This is a weird one and has happened quite a few times, but I’m just now getting around to posting it for some help.
    Every now and then when I go to save my FCP Project I get this error that says, “File Error: Unknown file.” In order to save the project I have to do a “Save Project As…” Not only will it not allow me to save over the current project, but I can’t even save the project on the same hard drive as the original regardless of what I name it. So I save the project on different drive, delete the original and then move the newly saved/created project back over and continue working.
    So I’m not sunk or anything, but this is obviously annoying. Any ideas as to why this would be happening?
    Appreciate the input!
    Timothy D. Allen
    https://www.timdan.com
    Andy Dykstra replied 16 years, 9 months ago 4 Members · 6 Replies
  • Jerry Hofmann
    October 21, 2008 at 2:30 am
    Try saving the project file in your documents folder exclusively. Shouldn’t be kept on a drive other than your startup disk.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Tim Allen
    October 21, 2008 at 5:22 pm
    Really? So my FCP Project shouldn’t be on the same drive as the media? (I have a secondary SATA Raid drive I keep all my footage on). Interesting. Is there a reason for that?
    Timothy D. Allen
  • Jerry Hofmann
    October 24, 2008 at 1:55 pm
    Yes. It’s a small file which needs to be saved often, and read all the time from a drive, so putting it away from the media drive keeps that drive running faster.
    Jerry
  • Rupert Watson
    November 28, 2008 at 12:41 pm
    Are you having a laugh?
    this is just an annoying bug in FCP.
    I suspect it may be permissions related but it has nothing to do with the frequency of access.
    Rupert Watson
    ROOT6 Ltd
    44 7787 554801
  • Rupert Watson
    November 28, 2008 at 12:45 pm
    Can I urge everyone this happens to hit the provide feedback in the FCP menu and provide feedback about this annoying bug.
    Rupert Watson
    ROOT6 Ltd
    44 7787 554801
  • Andy Dykstra
    December 2, 2009 at 10:57 pm
    We have several FCP machines set up working on the same projects from a storage server. All of our machines get this error occasionally, and it is almost always around 5:30pm. The time thing really throws me for a loop. All the drives are still up and can be read and written to by any other application any time. Not cool FCP. Not cool.
    http://www.ghostrender.com
