Activity Forums Apple Final Cut Pro Legacy File Error: Access Denied – cant open project
  • File Error: Access Denied – cant open project
    Posted by David Cohen on May 2, 2009 at 7:37 pm
    Hi all,
    Need some help here. I cannot open any project one one of my drives, FCP gives me the File Error: Access Denied. I tried to change the permissions (Get info) fix the permissions (disc utillity) copy the project, and move to another directory including locally. All other projects open fine in other folders. Help?
    FCP 5
    MacBook Pro osX 10.5
    2.4 intel core duo
    4G Ram
    Tamara Gurbis replied 14 years ago 9 Members · 10 Replies
  • 10 Replies
  • Ivars Bezdechi
    May 2, 2009 at 8:00 pm
    I just had this problem the other day.
    This is an easy fix.
    You need to go in and delete all of the prefs file for Final Cut.
    Here is what you need to do:
    1. Quit Final Cut Pro (although it sounds like you can’t open it anyway)
    2. Click the Finder icon in the Dock.
    3. From the Go menu, choose Go to Folder.
    4. Type: ~/Library/Preferences/ Note: The tilde “~” refers to your home directory.
    5. Click Go.
    6.Drag and delete the file named “com.apple.FinalCutPro.plist” to the Trash .
    7.Double-click the folder named “Final Cut Pro User Data”.
    8. Drag and delete the file named “Final Cut Pro Preferences” to the Trash.
    9. Drag and delete the file named “Final Cut Pro POA Cache” to the Trash.
    10. Drag and delete the file name “Final Cut Pro Obj” (or name thereabouts) to the Trash.
    What has happened is that the Prefs file contains your scratch disk info, Final Cut Pro settings and somehow it got corrupted (usually if something didn’t agree with the program). When you restart Final Cut Pro it will ask for the initial setup info. Then when you go to open the project you should be good to go.
    Let me know if this works! Best of luck!
  • Ivars Bezdechi
    May 2, 2009 at 10:08 pm
  • David Cohen
    May 3, 2009 at 12:08 pm
    Hi Ivars,
    Thanks for the reply – I tried it and alas the problem remains. I think the file(s) are corrupted. Not sure what to do now. Thanks again.
    Cheers
    -dave-
    Dave Cohen
    Motion Graphics * Digital Design
    http://www.daveswaves.net
  • Alexander Kallas
    May 4, 2009 at 4:58 am
    Look in the auto-save vault for previous project files.
    Cheers
    Alexander
  • Rafael Amador
    May 4, 2009 at 6:02 am
    Hi David,
    is difficult that all the files of a HD get corrupted at once.
    is more easy that they have some “File Finder Info” or so wrong.
    Run DiskWarrior, TechTools or similar.
    Rafael
    http://www.nagavideo.com
  • Tim Young
    May 31, 2009 at 7:05 pm
    Wow thank you!!!! wow i was scared.
  • Octavio Mancilla
    February 11, 2010 at 5:18 pm
    I just had the very same message error, but it happened only after rendering any part of my sequence, even after restarting FCP or even the computer.
    Just wanted to say, in case anyone finds the same situation, that the solution posted in here solved my problem.
  • Scott Mcdonald
    August 10, 2010 at 8:46 pm
    This helped with all of the early problems I was having with my Final Cut Pro 7 upgrade. I couldn’t even drag clips to the timeline without FCP stalling. Thanks sooo much for the advice!
  • Momoy Fuentebella
    September 29, 2010 at 5:49 am
    Thanks, Ivan. You’re a savior.
  • Tamara Gurbis
    August 24, 2012 at 8:00 am
    Though it has been three years since you offered the solution, it’s still helping editors in 2012. Thanks, Ivars!
