Activity Forums Apple Final Cut Pro Legacy File Error: Access Denied
  • File Error: Access Denied
    Posted by Joe Sinclair on January 7, 2009 at 12:12 pm
    Hello, I posted this a few days ago but I’m still having problems…
    I’m using FCP 5.0.1. When I try to open a project I saved on an external drive I am getting the message ‘File Error: Access Denied’.
    I am trying to open the file while logged on as a different user to the one I used when I created the file.
    This is because for some reason I cannot open FCP as the original user.
    I have tried trashing the preferences and repairing permissions but it makes no difference, either to being able to access the file, or to being able to log on to FCP as the original user.
    It must be something simple, any suggestions???
    Please and thank you…
    Joe
    Respond to this post • Return to posts index
    Re: File Error: Access Denied
    by Chad Cooper on Jan 4, 2009 at 11:32:43 pm
    Have you tried checking the permissions by doing a ‘get info’ on the file? Highlight the file then cmd+I. At the bottom is the permissions. It’s probably read only for your current user. If so, change it to read & write. You’ll need the admin password.
    by Joe Sinclair on Jan 4, 2009 at 11:42:19 pm
    Thanks, I hadn’t tried that but it was already on ‘read and write’ so it’s not making any difference…
    by Rafael Amador on Jan 5, 2009 at 3:21:12 am
    Try checking “Ignore ownership on this volume”.
    Rafael
    http://www.nagavideo.com
    by Joe Sinclair on Jan 5, 2009 at 10:53:14 pm
    Thanks, but this option is also already checked. Any more suggestions???
    Tony Kuhl replied 15 years, 11 months ago 4 Members · 3 Replies
  • Dennis Leppell
    January 7, 2009 at 6:07 pm
    like Raphael said, check the permissions on the file using the get info dialog….I’ve had to go so far as to add a new user/administrator. you can also try duplicating the file to your local drive.
  • Jessica Keen
    April 7, 2010 at 9:00 pm
    Hi Joe!
    I’m encountering this problem myself at the moment.
    I wonder did you ever find a solution to this problem?
    Jessica
  • Tony Kuhl
    October 4, 2010 at 12:52 pm
    Hi Jessica,
    Did you ever find an answer to your “access denied” problem? I am having the same issue.
    Thanks. Tony
