Activity › Forums › Apple Final Cut Pro Legacy › File Copy -> Disappearing RAID
  • File Copy -> Disappearing RAID
    Posted by Bob Cole on September 17, 2007 at 1:36 pm
    This may be a Mac OS X question, but it involves a file generated in FCP, so…
    I made a ProRes 422 HD file, 33 minutes, 35 gigs. Plays fine, in sync, in FCP.
    I backed up a bunch of files to a FW drive, one even larger than this one. Every time the copy procedure hits this file, it generates a “file can’t be read” message, ends the copy, and the RAID which is its home disappears. A restart brings the RAID back.
    When I restart:
    Disk Warrior – okay.
    When I run Disk Utility while FCP is running, I get “Verify Volume failed with error: could not unmount the disk.” But the disk checks out fine when I exit FCP.
    Any ideas what’s going on? Why I can’t copy the file? Why the copy operation makes the RAID go away?
    internal RAID, Mac Pro
    Bob C
    MacPro 2 x 3GHz dualcore; 2 GB 667MHz
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
    Bob Cole replied 19 years ago 1 Member · 0 Replies
  • 0 Replies
