Activity Forums Apple Final Cut Pro File Conversion / Dealing with Non-supported Codecs in FCPX
  • File Conversion / Dealing with Non-supported Codecs in FCPX
    Posted by Phil Thenstedt on April 3, 2018 at 1:32 am
    I’ve recently been given a bunch of AVI files that were created on a PC using either Huffyuv or Lagarith lossless codecs. On a PC the files play fine, but If I try to open on my mac I get sound but no picture and FCPX will not import the file.
    I did try converting with handbrake and it made an mpeg file that played back in quicktime, however I need to do some editing and processing so I prefer uncompressed lossless files to work with in FCP.
    Does anyone have experience doing conversions of these to a format acceptable for FCP? Wondering what software I might be able to use for the conversion and to what format I should convert.
    Thanks in advance!
    Phil Thenstedt replied 8 years, 5 months ago 2 Members · 3 Replies
  • Tom Ackroyd
    April 3, 2018 at 3:58 am
    If you have ffmpeg you can transcode from the Huffyuv and Lagarith codecs to the v210 uncompressed codec in a QuickTime wrapper, eg:
    ffmpeg -i input -c:v v210 -c:a copy output.
    Tom
  • Tom Ackroyd
    April 3, 2018 at 4:00 am
    Edited to add “.mov”
    ffmpeg -i input -c:v v210 -c:a copy output.mov
    Mac Pro 2 x 2.26 GHz Quad-Core Intel Xeon
    8 GB 1066 MHz DDR3
    OS 10.7.5
    FCP 10.0.6
  • Phil Thenstedt
    April 5, 2018 at 1:02 am
    Great so v210 uncompressed should be good for editing in FCP as well as for archiving then. Sounds perfect, I’ll give it a shot. Thank you!
