Activity Forums Adobe After Effects file compression
  • file compression
    Posted by Brianna Scarff on December 14, 2009 at 5:43 pm
    Need to compress two AF (CS4) videos for -high quality viewing- on Vimeo! Rendered as .MOV at several gigs – need to size down without losing the quality! I’m using a Macbook…
    currently, the two (several minutes in length) videos i have are at 720 x 480 and 960 x 540
    Brianna Scarff replied 16 years, 9 months ago 2 Members · 2 Replies
  • Walter Soyka
    December 14, 2009 at 5:50 pm
    Have you seen Vimeo’s guidelines on compression?
    https://www.vimeo.com/help/compression
    Also, you’d want to use Compressor or Quicktime Pro to do this compression with the high-quality MOV files you already have, rather than trying to use After Effects as a compressor.
    Walter Soyka
  • Brianna Scarff
    December 14, 2009 at 6:15 pm
    Thanks for the quick response –
    Aside from Compressor and Quicktime, are there any free resources available to compress videos?
