Activity › Forums › Apple Final Cut Pro Legacy › File based Closed Captioning workflow….any advice?
  • File based Closed Captioning workflow….any advice?
    Posted by Dennis Leppell on November 30, 2011 at 9:37 pm
    There’s a lot of info out there about closed captioning, but I can’t seem to come up with a definitive answer for what I need to do.
    So here’s the gist of things in a simplified version of what I’m trying to accomplish.
    I have a whole bunch of 6 minute videos that have been previously captioned on dv tape. I’m going to start getting a whole bunch more videos captioned in HD, and delivered on a hard drive. I need to take 3 of these videos at a time, place them on a timeline, and then need to deliver a HD captioned master. Simultaneously, I need to deliver a SD captioned master on Beta SP. FCP7 is our software of choice.
    I am trying to AVOID using MacCaption software, so please don’t recommend it unless there’s no other way.
    Using a Matrox MXO2 LE, I believe I can scale the standard def videos and retain captioning (both input and output). If this is correct, please let me know.
    What I really can’t figure out though is A) what format I need the caption house to deliver to me that has CC embedded in the video, and B) what format(s) can I export directly from FCP that will keep that CC in the video, with no additional steps involving .scc files and such. I’d like to utilize 608/708 captioning if possible
    Info I’ve read indicate that XDCAM, MPG2, and DVCPRO HD, but there’s no real cut and dry ‘this is how it’s done’ solution.
    I have seen info about capturing with ProRes will retain this info, but that workflow always has laying to tape as the final step.
    If and when I get this figure out, I’m SO doing a tutorial on it.
    Shane Ross replied 14 years, 10 months ago 2 Members · 1 Reply
