Activity › Forums › Apple Final Cut Pro Legacy › file attribute mismatch
  • file attribute mismatch
    Posted by Rosfer on March 20, 2007 at 2:55 pm
    HI Everybody!
    I’ve got this problem in FCP. A guy send me his project in XLM and I reconect all the files. When I’m reconecting appears that message
    “Some attributes of one or more of the files you hae chosen do not match the attributes of the original. This may cause problems within the sequences that are dependent on them. the attributes that differed are as follows: Media start and end”
    For my surprise the point “in” and “out” are moved.
    What can I do for restore these points?
    How Can I fix that prolem?
    Thanx
    Rosfer replied 19 years, 6 months ago 3 Members · 4 Replies
  • Captain Mench
    March 20, 2007 at 3:12 pm
    I hate to even mention this as it won’t answer your question….
    But –
    Was there speed changes to clips in the original project? I’ve had problems with XML taking along speed changes. Not sure how to fix it if indeed that’s the issue.
    CaptM
  • Rosfer
    March 20, 2007 at 3:18 pm
    I’m working at 24fps. The project that they send me was in 24 fps but they worked at 30.
    I think I’ve got to ajust it manually.
  • Mark Maness
    March 20, 2007 at 4:28 pm
    There’s your problem…. Get them to send you the 30 fps program and you’ll be fine until you have to convert to 24p.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Rosfer
    March 20, 2007 at 6:24 pm
    How Can I convert the XML archive in 24 fps?
