Activity Forums Adobe Premiere Pro Figuring out audio settings for FS7 Proxy encoding
  • Figuring out audio settings for FS7 Proxy encoding
    Posted by Alexandre Brandt on January 20, 2017 at 5:26 pm
    Hello all,
    I’ve got some nice FS7 UHD footage I’m trying to create proxies for in ProRes422 Proxy. I’m having some trouble with audio…
    When I go to Create Proxies and I select my Ingest/Encoding preset (made in Media Encoder) I get a message “The selected preset does not support the audio channel type of the clip 797_0065.MFX”
    My MFX clips have 8 channels audio, but only the first channel has audio on it, the others are without sound. I’ve tried playing around with my audio setting in my preset, putting Uncompressed 8 channels, trying mono, trying stereo, trying 24bit depth as the original clips, but I still get the message… It’s preventing me from encoding proxies…
    Any idea ?
    Producer | Filmmaker
    Geneva – Switzerland
    http://www.bingo-films.com
    Alexandre Brandt replied 9 years, 7 months ago 2 Members · 2 Replies
  • Daniel Waldron
    January 21, 2017 at 12:42 am
    You need to use a preset that uses a codec that can handle all the audio channels. ProRes or DNxHD, for example. If it’s H.264 or something similar, it will cause issues.
  • Alexandre Brandt
    January 23, 2017 at 3:35 pm
    I figured it out, I had to change audio setting for the clips, to mono with one channel (which is what was recorded) before creating the proxies. It all worked now.
