Activity › Forums › Adobe After Effects › Figured out problem now what do I do???
  • Figured out problem now what do I do???
    Posted by Bodybuildingbs on August 3, 2006 at 1:56 am
    I have found my problem but have no idea how to fix it.
    I start a new project.
    I create a comp.
    I import the footage which is 33 seconds and put it in the comp.
    I add the effect of timewarp.
    I now to go the timeline and notice that the slower I set the timewarp like 50% the more it cuts off the original footage. The only way I can scrub all the footage is to set it at 100% which is of course no timewarp effect.
    Tried rendering and it just cuts off the footage.
    Please advise.
    Thehardmenpath replied 20 years, 2 months ago 4 Members · 5 Replies
  • Mike Clasby
    August 3, 2006 at 3:08 am
    I don’t have AE7 but when I demo-ed it, I did a time Warp Test and if I remember right, you need to ReInterpret your footage.
    In the Project Window, right click you footage, Interpret Footage>Main, then set the loop to 2, for a 50% reduction of Time Warp and 3 if 33%. Hope that makes sense. It seems like they should have taken this into account when they made the plugin (if that’s possible) and made the reinterpret/looping automatic. But, maybe this isn’t your problem.
  • Bodybuildingbs
    August 3, 2006 at 3:08 pm
    This method doesnt seem to work do you have other ideas? Thank you.
  • Dan Blaim
    August 3, 2006 at 4:23 pm
    Have you tried using the stretch function when you expand the In/Out/Duration/Stretch pane on the lower left of the timeline window? Stretch your clip to 200% for a 50% reduction in speed. (This works well if the clip does not have alot of motion but looks pretty good. Of course timewarp may give you more control)
  • Bodybuildingbs
    August 3, 2006 at 9:55 pm
    Thank you but that doesnt appear to work either..I have tried stretching the original footage and the comp with no success…any other ideas? Thank you.
  • Thehardmenpath
    August 5, 2006 at 11:43 am
    Menu/Layer/Time/Enable Time Remapping.
    That lets you make the layer as long as you want. I think the remapping filter works after the remapping tool, so you don’t even have to edit the keyframes. Just apply this effect and make the layer 3 times as long.
