Activity Forums Avid Media Composer Fighting with IO Express and MC 5.51
  • Fighting with IO Express and MC 5.51
    Posted by Paul Flint on November 12, 2011 at 4:00 pm
    Hi, We’ve been using MC 5.5 with Mojo SDI as our main editing station for ages. Now I have to switch to HD, got IO Express a week ago. Installed latest AJA drivers and Machina.
    Launched MC, got the Avid Media Composer XENA IoExpress in the foot of my window – wow it worked I thought – is that just that easy. But then I got to do some tests and started to worry.
    Few problems I’ve stumbled upon:
    – when I press play on a timeline with sound I get a 1 sec of the sequence played then it stops with an error
    Exception: StreamingPlayConsumer::ExecutePass TIMEOUT
    but when I play it for the 2nd time it works ok but from time to time ( way to often in order to work with a director behind your back ) I get diferent error msg
    Exception: Legend Audio Communication error, Hardware Underrun
    Another thing is deck capture and output. I got Sony HDCAM deck connected but somehow I cannot make it work withing AVID. I’ve checked the connections. They are ok, I am able to capture, preview and control deck with AJA Machina software.
    So now the status is terrible since I cannot ingest, output at all, and playback is giving me errors as well. I got few days to make it work or else I’m back to old SDI Mojo.
    Maybe I should deinstall MojoSDI drivers first ?
    Sonn there will be MC6 but untill I make that purchase – spring 2012 earliest I need to make this thing work
    Any suggestions ?
    Info on my rig
    HP Z800 8 Gigs of RAM
    Windows 7 64bit SP1
    MC 5.5.1
    thanks in advance
    Flint
    Paul Flint replied 14 years, 9 months ago 3 Members · 3 Replies
  • Job Ter burg
    November 12, 2011 at 8:18 pm
    I’d first try an upgrade to 5.5.3.1, the latest version of 5.5.
  • Brad Warren
    November 14, 2011 at 11:47 pm
    Having the same problem.
    Same system same specks.
    I don’t have an avid service account. If the update works let me know and i may have to invest in one.
    Thx
    Brad
  • Paul Flint
    November 16, 2011 at 4:19 pm
    I did an update to version you suggested, nothing changed. I’ve managed to figure out a way for remote deck control so I can ingest and output. I had to use RS input on Z800 not on IO Express in order to make it work.
    Still got that audio issue that I cant rid off.
