Activity › Forums › Adobe After Effects › Fiery atmosphere – how to?
  • Fiery atmosphere – how to?
    Posted by David Del on September 12, 2009 at 12:58 am
    I want to create a scene from ‘hell’ where the atmosphere is fiery, almost like when you look through a flame, distorted – I guess the HAZE effect in the summer on the road might be the best way to describe it – the air is not necessarily ‘on fire’ but distorted like what happens in a fire. Any ideaS?
    Jeremy Fabiano replied 17 years ago 3 Members · 2 Replies
  • Todd Kopriva
    September 12, 2009 at 2:20 am
    Here’s a Community Help search for ‘heat haze’ that brings up plenty of answers. Many of them are variations on the theme of 1) creating a noise layer and 2) using that as a the control layer for an instance of the Displacement Map effect.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Jeremy Fabiano
    September 13, 2009 at 5:55 pm
    It might work also to take one of those haze ideas… but add to it.
    I’d precomp my footage, apply the haze to the precomp, then go INTO the precomp, add a reddish-orange (fire/hell?) colored solid over top, turn the opacity to maybe 10-30, switch to additive transfer mode, and maybe (if you dont want the main shot colorized) mask off w/ subtract below the ‘horizon’ level (don’t forget to feather it).
    That should give you your ‘hell’ish atmosphere.
    Could also add an adjustment layer with a glow effect to kind of make it “pop” out at you and wrap around objects.
    Good luck, hope this helps!
    Show us the final when you get it doen 🙂
    -Jeremy
