Activity › Forums › RE:Vision Effects › FieldsKit – 50i to 50p (1080)
  • Chris Wright
    January 13, 2011 at 9:02 am
    some people like to keep it simple and put a 50i(25interlaced) video into an after effects 50 fps comp so that each field becomes a frame. Others like to deinterlace with plugins or hardware boxes then retime with optical plugins.
    from fieldskit manual pdf
    for fieldskit timing mode:
    2x FPS,1 Frame Per Field, place in double framerate comp, interpret fields off in AE.
    https://technicolorsoftware.hostzi.com/
