Activity › Forums › Adobe After Effects › Fieldskit 2.0 Render – Problem with Premiere Pro 2.0
  • Fieldskit 2.0 Render – Problem with Premiere Pro 2.0
    Posted by Alexander Schwingel on December 21, 2007 at 6:43 pm
    I am using the Fieldskit 2.0 Deinterlacer with Premiere Pro 2.0.
    If I render the timeline or export a movie the plugin reports a failure and the render progress is canceled.
    Are there any special settings for Fieldskit on PP2.0? I am using the standard settings.
    Pierre Jasmin replied 18 years, 9 months ago 2 Members · 1 Reply
  • Pierre Jasmin
    December 21, 2007 at 7:49 pm
    Can you send us a 10 frames project with a source movie in the codec you use at techsupport@revisionfx.com and we will look at it…
    Do you notice if this happens at the last frame?
    Pierre
