Activity Forums VEGAS Pro Fields order
  • Fields order
    Posted by Paul Avagian on September 13, 2007 at 9:46 am
    How can i really change the captured dv files field order from low to up first. I use PAL SD/IMX project properties with up field . When i change the field order nothing happens.The final render DV avi file with up filed is jerky(only when the DV clips appear.)I use this settings because most footage of this project is from dvd’s imported with Vegas.
    Douglas Spotted eagle replied 19 years ago 2 Members · 1 Reply
  • Douglas Spotted eagle
    September 13, 2007 at 12:56 pm
    Change the field properties at the event level vs the project level. They’ll need to resample (should be smart-resamping anyway).
