Fields order
How can i really change the captured dv files field order from low to up first. I use PAL SD/IMX project properties with up field . When i change the field order nothing happens.The final render DV avi file with up filed is jerky(only when the DV clips appear.)I use this settings because most footage of this project is from dvd’s imported with Vegas.
