Activity Forums Blackmagic Design Fields handling
  • Fields handling
    Posted by Pasi Koivisto on September 12, 2006 at 5:51 am
    Hi all.
    Do the decklink drivers support field dominance? I do a lot of online work and a lot of my material comes as DV files and as I live in PAL land it’s lower field and I usually recompress to uncompressed. Hence I have a problem with field dominance on a lot of my projects. So, if my Decklink card could understand the field dominance setting on the clips I would be a happy chap. Is this possible? Have I missed something?
    Kristian Lam replied 20 years ago 4 Members · 5 Replies
  • Rafael Amador
    September 12, 2006 at 12:21 pm
    Hi DopeElf,
    BM handel properly the field domminance. However, FC try to do the same and when you lie Lower-first footage in a Upper-first time-line, or viceversa, FC sets the “Shift-fields” effect to the footage. Just uncheck the effect and the rendered film will look perfect.
    salud,
    rafael
  • Luke Maslen
    September 13, 2006 at 3:04 am
    Yes, DeckLink will handle the field issues with your PAL DV video and we have a support note that covers this named “DV clips in PAL format look weird“. I’ve copied the text below as it covers this issue and more.
    Why does DV material look bad when exported to uncompressed?
    The reason DV files look weird, is because the field order is wrong. The DV spec was designed with the wrong field order for PAL. On every other system, PAL is rendered upper field first, and this is how all video media and hardware works. However with DV, it
  • Pasi Koivisto
    September 13, 2006 at 9:39 am
    That’s what I usually do. Now, what I would like is to adjust the field dominance setting on the clip and have my card change the dominance on the fly, in realtime and mixed in a timeline.
  • Rafael Amador
    September 13, 2006 at 12:10 pm
    Hi Luke,
    I do as you say. I oppen a BM10B Uncompress, Upper-First sequence in FC. I drag a DV clip. Automaticly FC sets the”Shift-fields” effect. If I just render like that, the film is rendered in the wrong order and watch it is a headache.
    if I simply uncheck the filter, the result is optimum. This is contradictory with what the article about DV says. I have a JVC monnitor, and work with FC 5.0.4.
    rafael
  • Kristian Lam
    September 14, 2006 at 12:34 am
    Yes, Final Cut Pro automatically applies a shift field filter if it detects a different in field dominance between the clip and the configured timeline. The video then gets passed on to out output component. Unfortunately, this doesn’t quite happen correctly in Final Cut Pro 5.1.1 but should be addressed in the upcoming 5.1.2 release.
    regards
    Kristian Lam
    Blackmagic Design
