Activity Forums Adobe Premiere Pro Fields Blending in DV NTSC
  • Fields Blending in DV NTSC
    Posted by Benjamin Kruse on March 9, 2007 at 3:25 am
    I am trying to use a interlaced video I created in After Effects in Premiere, but Premiere blends the fields together, rendering the video pixelated. How do I keep this from happening?
    Extra info:
    – The fields are blended when I export to tape as well.
    – If I compose the video in “Desktop” mode, this doesn’t happen, but Premiere won’t export to tape.
    Please help. All my video looks terrible because of this.
    Thanks.
    Tclark replied 19 years, 6 months ago 2 Members · 1 Reply
  • Tclark
    March 9, 2007 at 1:52 pm
    Are you exporting from After Effects? If so, Don’t! Use dynamic link. It looks like you are exporting from After Effects with the wrong settings. If you still want to export from After Effects make sure you are rendering the correct field order. If that does not work make sure that your composition setting are correct.
